I'm new to Labview, and I've encountered an example with a dialog that allows to define a path to a file. If I open the properties on the block diagram of this block the name of the block appears to be "Path Properties: Project file:" The default value points to a different place than where the file installed and the VI won't run untiI I change the path. If I save and open the file, it doesn't remember the change. When the vi is running I can right click the text and there is an option to reinitialize to default. I've rooted around all over the place and can't find where this can be set or changed. How do I change this?
