How to change 1D ARRAY to singles single string elements
     I have a row of data from sql
     It's have more data in row
     I need to split those data's
    Ex :
       Actual data
        "Rajesh","ramesh","raj"
       I expect element by element
        Element 1 Rajesh
        Element 2 Ramesh
        Element 3 Raj
Message 1 of 16
(1,757 Views)
    Ex :
       Actual data
        Element 1 Rajesh
        Element 2 Ramesh
        Element 3 Raj
Your title is confusing. It is not clear what you have and what you want.
If ["Rajesh","ramesh","raj"] is a single string with comma delimiters, you can convert it into a 1D array using "spreadsheet string to array".
Assuming   ["Rajesh","ramesh","raj"] is a 1D array of string with three elements, you can use index array to get any one. If you want to process them in order, autoindex using a FOR loop to iterate over the elements.
It would help if you could attach a simple VI that has your input and desired output.
Message 2 of 16
(1,747 Views)
Hi Raj,
    Ex :
       Actual data
        Element 1 Rajesh
        Element 2 Ramesh
        Element 3 Raj
To split a string into an array of substrings based on a delimiter char you may use SpreadsheetStringtoArray.
To remove quotation marks from strings you may use SearchAndReplaceString.
What have you tried and where are you stuck?
Message 3 of 16
(1,746 Views)
I used "Spreadsheet String to Array" to separate my incoming data into individual lines. Now I have something like this:
["%f, %f, %f", "%f, %f, %f", "%f, %f, %f", ...]   Each string contains three comma-separated values.
What I would like to do is extract the three values from each string and place them into three separate float arrays.
For example, given:
["1,2,3", "4,5,6"]
I want to obtain:
Array 1: [1.0, 4.0]
Array 2: [2.0, 5.0]
Array 3: [3.0, 6.0]
How can I do this efficiently in LabVIEW?
Thanks in advance!
Message 4 of 16
(882 Views)
Hi Quinon,
  1. Use a FOR loop to iterate over each string.
  2. Inside the loop you use ScanFromString (as you already know from your other threads) to get three float values.
  3. Use autoindexing tunnels to create your required arrays…
Autoindexing is very efficient in LabVIEW!
Message 5 of 16
(866 Views)
You can convert a spreadsheet directly into a 2D-array if rows are separated by newlines
spreadsheet string to 2D arrayspreadsheet string to 2D array
Message 6 of 16
(850 Views)
I tried something like this, but I'm getting an error with the Scan From String block:
And I also tried this, but it only shows 0...
Message 7 of 16
(833 Views)
@Ouinon wrote:
I tried something like this, but I'm getting an error with the Scan From String block.
In your first String to Array the Format just should be "%s" instead of 3x %f (you're grabbing the whole line as a string)
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 16
(822 Views)
Even after changing this parameter, I still get the error:
LabVIEW: (Hex 0x55) The scan failed. The input string does not contain data in the expected format.
Message 9 of 16
(809 Views)
How does your input string look like? Can you give a verbatim example? Use probes and indicators to inspect the incoming data.
Message 10 of 16
(795 Views)
