How to call a labview dll from visual c++ 2005/2008
Hi
I am looking into making some DLL files in LabVIEW 8.5 that can be called from other programming environments. Initially I want to call a simple DLL that multiplies two numbers and gives the result. I have made the VI / DLL with the corresponding in- and outputs and compiled it. So now I have got my DLL, SharedLib.h, SharedLib.lib etc.
Can anyone now show me how I can call this DLL from e.g. Visual C++ 2005/2008?
Best regards
Simon
LabVIEW 8.6 / 2009 / 2010
Vision Development Module 8.6 / 2009 / 2010
VBAI 3.6 / 2010
(3,984 Views)
Will this be using .NET? If so, you may want to take a look at this article: How Do I Use a LabVIEW DLL in Microsoft Visual Studio.NET?
(3,973 Views)
Hi Smercurio
Yea it's something like that I am looking for, especially the example from MSDN with a C++ example.
To be honest, I don't normally program in C++, I just have to do some pretest on some DLLs before I send it on to some other people:-)
So, the C++ example I found to be the closest one to what I need, is
using namespace System::Runtime::InteropServices;
typedef void* HWND;
[DllImport("user32", CharSet=CharSet::Auto)]
extern "C" IntPtr MessageBox(HWND hWnd,
String* pText,
String* pCaption,
unsigned int uType);
void main(void) {
String* pText = L"Hello World!";
String* pCaption = L"Platform Invoke Sample";
MessageBox(0, pText, pCaption, 0);
 To call my DLL, I have got the following parameters
       double mycalculator(double myinput1, double myinput2)
which returns a result.
To test this I have installed Microsoft Visual C++ 2008 Express Edition.
Now I just need some clever people to help me with a little test example 🙂
Best regards
Simon
VBAI 3.6 / 2010
(3,946 Views)
Here's an older tutorial but it still applies for newer versions of LV and Visual Studio. Should do the trick.
-snow
CTA, CLA, MTFBWY
(3,913 Views)
That tutorial does not apply to .NET. .NET calls DLLs as unmanaged code. Visual C++ 6 had no concept of managed/unmanaged calls.
(3,886 Views)
Are you using Managed C++? You didn't specify that in your original post. If you're using Unmanaged C++ then the tutorial is still relevant.
Anyway, if you're using Managed you use PInvoke instead of natively calling the dll.
-snow
CTA, CLA, MTFBWY
(3,872 Views)
