How to calculate signal area
@GerdW
Yes this part will not work all the time.
Thanks for pointing out.
Corrected.
PBP
Labview 6.1 - 2015
Message 11 of 15
(140 Views)
Hi PBP,
one more point: all your FOR loops can run too many iterations based on what they do: the last iterations might index non-existing array elements…
using LV2011SP1 + LV2017 (+LV2020 sometimes) on Win10+cRIO
Message 12 of 15
(130 Views)
Hi GerdW,
Can you throw some light how can I avoid some for loop when I want to do calculations online? I am using this method to detect start and stop of my waveform.
PBP
Labview 6.1 - 2015
Message 13 of 15
(116 Views)
  • What is your definitition of "calculation online"? Where exactly is that?
  • You can subtract 3 from all your values wired to N.
  • Your loops differ very little. I am sure you could combine the bulk of the code to avoid all that repetition.
  • It is a really bad idea to place user files into the root folder (C:\data.csv).
  • Your code does not work right if the first peak is negative.
LabVIEW Champion. It all comes together in GCentral GCentral
What does "Engineering Redefined" mean??
Message 14 of 15
(106 Views)
@altenbach
1) What is your definitition of "calculation online"? Where exactly is that?
Calculation online means this is performed on live data not on the past data. Where I don't know at what sample my cycle will start. Position of peak will very anywhere between samples I captured.
2)Your loops differ very little. I am sure you could combine the bulk of the code to avoid all that repetition.
This is just example code actual code contains subVis for code repetition.
3) It is a really bad idea to place user files into the root folder (C:\data.csv).
This is just example for Rani_jcha's question. Path can be anything.
4)Your code does not work right if the first peak is negative..
In my case I am capturing sine wave signal and I do soft firing of TRIAC, so I always get positive peak first.
PBP
Labview 6.1 - 2015
Message 15 of 15
(90 Views)
