How to calculate signal area
@GerdW
Yes this part will not work all the time.
Thanks for pointing out.
Corrected.
PBP
Labview 6.1 - 2019
Message 11 of 15
(904 Views)
Hi PBP,
one more point: all your FOR loops can run too many iterations based on what they do: the last iterations might index non-existing array elements…
Message 12 of 15
(894 Views)
Hi GerdW,
Can you throw some light how can I avoid some for loop when I want to do calculations online? I am using this method to detect start and stop of my waveform.
PBP
Labview 6.1 - 2019
Message 13 of 15
(880 Views)
  • What is your definitition of "calculation online"? Where exactly is that?
  • You can subtract 3 from all your values wired to N.
  • Your loops differ very little. I am sure you could combine the bulk of the code to avoid all that repetition.
  • It is a really bad idea to place user files into the root folder (C:\data.csv).
  • Your code does not work right if the first peak is negative.
Message 14 of 15
(870 Views)
@altenbach
1) What is your definitition of "calculation online"? Where exactly is that?
Calculation online means this is performed on live data not on the past data. Where I don't know at what sample my cycle will start. Position of peak will very anywhere between samples I captured.
2)Your loops differ very little. I am sure you could combine the bulk of the code to avoid all that repetition.
This is just example code actual code contains subVis for code repetition.
3) It is a really bad idea to place user files into the root folder (C:\data.csv).
This is just example for Rani_jcha's question. Path can be anything.
4)Your code does not work right if the first peak is negative..
In my case I am capturing sine wave signal and I do soft firing of TRIAC, so I always get positive peak first.
PBP
Labview 6.1 - 2019
Message 15 of 15
(854 Views)
