How to calculate percentage of two signals in the graph?
@rdeletric wrote:
Hi, they are signals received by the line-In input of the microphone. be an oscilloscope by the sound card.
I don't see how that is relevant to your final result.  Again, what algorithm are you supposed to be using to get your "similarity" number?  Once you define that, then we can start coding it up.
Message 11 of 14
(708 Views)
in line-in input, such as 2 channels. receive two types of signals. What I'm trying to do is compare one signal to the other. Example compare signal 2 for signal 1.
Message 12 of 14
(707 Views)
No advancement to any solution.
Message 13 of 14
(672 Views)
Hi rd,
Then you need to work on it!
What have you tried in the meantime?
Which algorithm do you want to implement?
Message 14 of 14
(663 Views)
