How to calculate percentage of two signals in the graph?
Hello, good afternoon guys Does anyone know how to calculate the percentage of the signal by comparing as this graph the signal Blue by Red, giving result in percentage of similar?
I already tried to divide it and the result multiplied by 100 but it does not work.
Message 1 of 14
(4,123 Views)
Hi rdelectric,
please define "similarity" when you want to calculate a "percentage" for that!
Hint: try to get rid of express VIs and DDT wires to get a better understanding of LabVIEW...
Message 2 of 14
(4,119 Views)
In the graphic I have the signal in blue and the signal in red. Blue will always vary, red will be the default.
When the blue varies I must calculate the percentage that the blue signal looks like red.
Message 3 of 14
(4,113 Views)
Hi rdelectric,
So again: please define "similarity"...
Do you want to compare amplitude? Phase? Frequencies? A mixture of some or all those parameters?
Message 4 of 14
(4,108 Views)
Exact, I want to compare, the mix of all the parameters.
What I have achieved so far has been to compare only values as amplitude.
Message 5 of 14
(4,104 Views)
Hi rdelectric,
you still aren't able to provide a definition of your desired value...
What about using a FFT to determine main frequency with its amplitude, and maybe the "noise" of all the other frequencies in the spectrum?
After all this discussion you still NEED to define a formula for your "similarity"!
Message 6 of 14
(4,088 Views)
Thanks for the help but my knowledge is still small. I'll search what you told me. Thank you
Message 7 of 14
(4,083 Views)
I did this this way, but it does not work correctly, I'm researching on FFT
Message 8 of 14
(4,062 Views)
How can you say it does not work when you have yet to define what it should be?  As has already been said, you need to define EXACTLY what you are looking for.  You seem to already have a number you are looking for.  Do you know how that number was previously calculated?
Message 9 of 14
(4,034 Views)
Hi, they are signals received by the line-In input of the microphone. be an oscilloscope by the sound card.
Message 10 of 14
(4,025 Views)
