08-18-2009 08:01 AM
Hi, everybody
I have a problem about how to use LabVIEW 8.5 to build a simple analog DEMUX.
For a example, I have a 3 channel analog MUX and the MUX have a sequential output.
The problem is that how can I divide this output into three signals properly.
(Three signals may be SIN waves with the different frequency.)
The parameter "T" can be controlled from 1 sec to 0.000001 sec according to CLK.
TNANKS
08-18-2009 09:12 AM
Hi Nikeho
This is not so simple. But one solution i can think of is as you know T and you know your sampling frequency you could calculate the number of samples that belong to each channel. If you read the signal as an array you would then have to split it into subarrays according to the number of samples belonging to each signal. Does that sound like a workable solution? I'm not sure how robust it would be, that depends on the switching time of your MUX and a host of other factors. Could be worth a try though.
Best Regards
David
NISW
08-18-2009 09:17 AM
NIKEHO,
Can you provide a few more details about your mux and how it works? Does it output any kind of clock/sync signal? What NI hardware are you using?
