How to automate MS Access to set Password
Hello Labview Help:
I'm trying to automate the setting of new password in Microsoft Access 2003 or 2007 Database Application.
in Labview Activex or Visual Basic.
Here is where the NEW password would be written.
It would be great if you can help or point me to the right place.
I tried looking at MSDN info, but quite complicated.
The hardest part is how to navigate to the other objects within Microsoft Access with Activex.
thank you,
diego2000
Message 1 of 9
(4,752 Views)
If you have the DatabaseConnectivity Toolkit and an open connection to the DB, you should be able to use an Execute Query to modify the password.
http://msdn.microsoft.com/en-us/library/bb177884(v=office.12).aspx
ALTER USER user PASSWORD newpassword oldpassword
Message 2 of 9
(4,742 Views)
Hi Phillips:
Yes, I have the Database Connectivity Toolkit.
I will try the command and will report back. It should work.
thanks,
Diego2000
Message 3 of 9
(4,732 Views)
Hi Phillip:
I have tried what you sugested. Getting close but getting an error.
Looks like I'm missing a file?
I have also tried the "ALTER DATABASE PASSWORD new1 old1" following command:
Thanks for your help,
diego2000.
Message 4 of 9
(4,726 Views)
The link I provided had a comment at the bottom stating that the db should be opened exclusively with a mode=12 connection string option. Maybe that would address the error you received.
Message 5 of 9
(4,723 Views)
Phillip:
This is how I'm opening the Access Database. Where would I write the mode=12   ?
Where would I write the "mode=12" ?
Provider=Microsoft.ACE.OLEDB.12.0;Persist Security Info=False;Data Source=C:\New3.mdb
thank you much,
diego2000
Message 6 of 9
(4,718 Views)
Should be able to add Mode=12; to end of string...
From the link:
OleDbConnection objOleDbConnection = new OleDbConnection("Provider=Microsoft.Jet.OLEDB.4.0; Data Source=Sample.mdb; Mode=12");
Message 7 of 9
(4,716 Views)
Thanks Phillip:
I'll try to convert to a Labview statement.
diego2000
Message 8 of 9
(4,697 Views)
Phillip:
On second thought, how would you change the password of Access with Visual Basic or VBA?
I'm downloading Visual Basic now.
thanks,
diego2000
Message 9 of 9
(4,687 Views)
