04-19-2012 07:28 AM
Hi, I want to plot data into a chart. I make a selection switch for each channel, there are for temperature measurement and voltage measurement.
What I want is when I switch the selection to temperature measurement, the Y-axis´s name change into Temperature and when it is voltage change into Voltage.
Can LabView do that ?
Citras
Solved! Go to Solution.
04-19-2012 08:16 AM
There are a lot of things that you could do to make your life easier in your code but here is how I would start with the question that you asked.
04-19-2012 08:34 AM
Thx for the response, yeah I think my labview program is too complicated. I am still new to labview, I don´t really know how to simplify it.
And for your example that you attached, I can´t open it. My labview is version 10.
Can you tell me what is the name of the components that is used ?
Citras
04-19-2012 08:43 AM
Property nodes are used to programmatically change properties of front panel objects at run time. You can generate property nodes in one of three ways:
This is a use of VI server. You may want to look at the LabVIEW help for VI server.
04-19-2012 08:53 AM
Here is a version that should work.
04-19-2012 09:57 AM
Thx for the solution, one more question, how to create the component in the middle ?
04-19-2012 10:03 AM
04-19-2012 10:10 AM
Right click on the graph and follow below
