08-20-2009 05:36 AM
Alright Rolf. I think I can get started now. Thanks for your help.
12-21-2010 07:04 AM
Good morning,
Excuse me for my bed english,
I 've create a custom driver for my usb hid device an i want to tell windows to use this driver in place of the standard one. I want tn know how to tell the installer to do this using key register like assigning extension and custom icon to executable.
12-22-2010 05:53 AM
This is not the right forum for this I think. This is specifically about LabVIEW software, but what you are asking is about Windows driver development and you would be better served by asking these questions on a Microsoft Windows driver development board, maybe with MSDN.
12-22-2010 11:56 AM
Tanks for your answer,
but I want to do that under labview installer, and i haven't understand teh explanation and exemples of MSDN (by microsoft)
I found that exemples of NI labview are very clear an i want an exemple like this How Do I Associate Custom File Extensions with an Application Built in LabVIEW
In this link (http://digital.ni.com/public.nsf/allkb/9538A36E218F10A4862571A8005EF6C0)
Thank for your help
12-27-2010 11:05 AM
Hi bslimanea,
Take a look at this Knowledge Base article: Change Default Instrument Driver Download Directory
Let me know if this works for you.
Ricky
12-27-2010 11:38 AM
Hi Ricky,
Thanks for your replay.
I think that i have'nt explain my problem clearly. I have a card based on microcontroller that communicates with the PC via USB HID mode. As soon as I connectthis card to my PC,Windows assigns a default drivers and my card is not visible from labview.but if I install this driver manually by the device manager labview recognizes my card.
what I want to do, is how to automate the installation of the driver that I do manually.
excuse me for my bad english.
thaks for your help
12-28-2010 08:48 AM
Hi bslimanea,
It seems we can try a couple things. I will still be checking to see of an automated program to do this for you, but from what I am seeing right now we do not have an example of that.
1) If you do not want this default driver assigned, try removing this driver from your computer. If your card works fine without this driver, and you can manually choose another one, un-install the default driver. Once you do this, you should be able to make the driver you desire your cards default driver, because it will be the only one the computer recognizes as compatible with your card.
2) Try moving the default driver into the "instr.lib" found through the path: Program Files\National Instruments\Labview\instr.lib
If the driver is in this folder, it should be able to communicate with labVIEW.
Give these a try. I will continue to search for an automated way.
Ricky
12-28-2010 10:44 AM
Thanks Ricky,
The first solutionis not possible because the driver is used by HID devices like mouse and keybord
The second solution is not clear. how can i copy the driver in the instr.lib (may driver is an .inf file generated by driver wizard.
Is it possible to have the syntaxe of DriverWizardInstallInf64.exe located in C:\Program Files (x86)\IVI Foundation\VISA\WinN (par of NI VISA wizard) it seems to be able te sove the problem.
The NI driver wizard call this executable to install the driver generated by the wizard (but i dont know how the wizard transfers the arguments (driver name) to this program
Thanks for your precious help
12-29-2010 10:19 AM
Good Morning bslimanea,
Try using this Knowledge Based Article and its associated Developer Zone Tutorial.
I believe these should be of assistance in this.
Ricky
01-18-2011 06:39 AM - edited 01-18-2011 06:40 AM
Hello, Please help.
In fact usually I install the drivers generated by the driver wizard of labview, but following the installation steps I found this wizard calls a file called DriverWizardInstallInf64.
The
wizard transfers the data necessary to install the driver and change
the registry so that Windows loads the driver installed instead of the
driver standad (USB HID).
Since
I like to make the driver installation process and modifying the
registry programmatically (automatically), I want to know how the data
(the path of inf file, the VID and PID of the material) are transferred
to DriverWizardInstallInf64 argument.
Ie what is the syntax of this file? so I can call it from the Windows command window.
Thank you for your help
