05-22-2007 02:34 AM
05-22-2007 03:47 AM
I am going to assume that you have a GPIB card so that you can connect your GPIB cable from your spectrum analyser too.
I would suggest checking the NI website or the Instrument vendor to see if there is a LabVIEW driver library for your instrument.
If you have a labview driver, there is usually is a Getting Started VI which you can use to driver the instrument to make sure you have communication.
After that, its a case of checking the driver to see it has a VI that perform the function/ task that you require. If its one of the common data retrival functions then you should find one in the driver. But a spectrum analyser has many functions and not all of the them are available in the driver. Therefore, it will be a case out with the Program Manual for the Instrument and create your own VI's.
Hope this helps
Regards
Ray Farmer
05-26-2007 01:42 AM
Thank you very much.
Rgds,
Guan Xiong
05-27-2007 03:36 PM
05-30-2015 11:05 AM
hello sir i am sunny
sir in my project i have interfaced labview with hardware spectrum analyser using d drivers
