How to apply the Classical Filter Design Express VI
I use the Digital Classical Filter Design VI to design a bandpass filter (try to follow this example http://www.ni.com/white-paper/4460/en/) but then I cannot locate
Filter Express VI in order to use the filter
Message 1 of 8
(4,561 Views)
Did you purchase the DFD toolkit?
Message 2 of 8
(4,545 Views)
Well, I have the trial version. For filter and control, I normally use Matlab but then I figure LabVIEW has some of the advantage - especially GUI. I am still making decision whether I should make purchase on LabVIEW toolkit.
Message 3 of 8
(4,538 Views)
You have both the trial version of LabVIEW and the DFD toolkit or just LabVIEW?
Message 4 of 8
(4,524 Views)
Just the toolkit - I can go with the Matscrip if I cannot find the vi.
Message 5 of 8
(4,509 Views)
Your answer does not make any sense. You either have both or just LabVIEW. You cannot have just the toolkit.
Message 6 of 8
(4,499 Views)
Sorry for my English/ I meant I just have LabVIEW, the toolkit is the trial version from NI download. At my company (non-engineering firm), all are trial and going to expire soon. I studied engineering but after graduated I joint to work as none-technocical work.  I am afaird that one day I will not be able to remember anything about engineering, thus I do something to retain some knowledge. I saw LabVIEW so I order LabVIEW RIO Evaluation Kit to learn something but then I am of lacking a lot of LabVIEW skill.
Message 7 of 8
(4,495 Views)
Accepted by topic author muahang1234
The filter express VI comes with LabVIEW base development system. It can be found in the functions palette under Express>>Signal Analysis>>Filter. Did you check here?
Message 8 of 8
(4,492 Views)
