How to apply filter to image Thersould USB webcam
Hello everyone. Someone knows how to RGB image (imnediatemente captured from a USB webcam) you can apply a filter Thershould?.
As much as I tried I did not succeed.
I could only apply the filter to an image stored on the hard disk.
I hope someone can help me.
Thank you.
(3,302 Views)
Did you get any errors?
(3,294 Views)
Thanks for responding. It happens that I fail to see the processed image (thershould through the filter). I used the VI generated from the VDM (applying the filter thershould to an image file), I have modified and added an earlier stage of image capture via webcam. I think my mistake was to use this VI generated.
Any suggestions?.
Sorry, I could attach a picture or vi.
Thank you.
(3,290 Views)
Can you see any images straight from the camera, or only from local files?
(3,279 Views)
Hello. I can see the image of the webcam, but I can not see the image resulting from applying the filter thersould. I will try to raise the file.VI or failing a picture of what happens.
Thank you.
(3,258 Views)
Not sure if this will help (and without seeing the VI I can't say for sure), but try turning the image display into snapshot mode.
(3,251 Views)
