05-09-2014 04:02 AM
I have 10 combination field boxes in my VI. I want to disable these combinations field when I run this VI. I know how to do it using property node but only for one obect. If I do this way I have to use 10 property nodes to disable all the field boxes. Is there any to use only one property node to disable all these combination boxes.
thanks in advance.
05-09-2014 04:16 AM
You need to make reference for every control then build them all under one array. Give this array to property node using for loop.
Find out vi in attachment for reference.
05-09-2014 04:22 AM
got it..................thanks....:)
05-09-2014 04:29 AM
Great then you should now accept this post as solution.
