03-16-2018 08:12 AM
Hi everyone,
I wrote a program to acquire a current signal of 4mA-20mA using cDAQ9185 and NI9227. The acquired siganl contains noise and inoder to eliminate it, I used Filter Express VI and selected Smoothening filter-Triangular-1000. But, I want to design a filter in proper way.
Inoder to do so, I took FFT of the Signal to determine the frequency at which Spikes are Present. I got only Amplitude of the Spikes.
Could you please guide me how to get the frequency at which the Spikes are Present and any other method to Analyse the noise and eliminate them.?
Please find the attached VIs and Screenshots
Best Regards,
Deepa
03-16-2018 08:41 AM
Hello Deepa,
I can't open your program, because I use LV 2015.
I have a question : wihich component of your signal do you measure ?
AC component or DC component.
I think, you should read to guideline :NI-9227
Anyway, I can say this :
You will be able to identify the frequeny of your Signal and eliminate the undesired signal by using the filter.
Fred.
Kudos are welcome!
03-16-2018 08:49 AM
Hi Deepa,
don't display the FFT results in charts - use graphs instead!
I also suggest to convert your DDT wires into waveforms (instead of plain 1D arrays). Then use "FFT Powerspectrum and PSD" instead of the plain FFT…
03-19-2018 04:29 AM
Hi Fred,
Thanks a lot for your reply. Its DC component.
Please find the attached VI in 2015 Format.
03-19-2018 04:37 AM
Hi Gerd,
I made the changes which you have mentioned.
In the graph, I can observe that, the start frequency is Zero and the amplitudes are 14, 14 and 24 for my three acquired signals. Could you please guide what does that mean?
I also added a Frequency and Amplitude search vi. and got the frequency of the Signal to be 50Hz and 49Hz, its varying. Are these frequency the required Signal frequency else the freuency of the noise. Please guide me
Thanks in Advance
Best Regards
Deepa
03-19-2018 04:58 AM
Hi Deepa,
Do ou know anything about FFT and spectral analysis?
The first value of the FFT is always at 0 Hz and describes the DC part (or offset) of your signal. I guess you yre NOT interested in this DC part…
I don't kow what you are expecting to see…
Which frequencies do you expect?
03-19-2018 05:27 AM
Hi Gerd,
The signal which i acquired are noisy.
I just want to get a stable signal. So, trying to find a noise frequency of the signal. Inorder to eliminate them using a filter.
In the smoothening filter which I used, I am not getting the signal exact value. I am working with these VI for the first time. Sorry, I ll learn about FFTs.
03-19-2018 05:40 AM
Hi Deepa,
Usually it's the other way around!
- "Noise" usually has a wide-spread spectrum ("uses a wide range of frequencies")
- "signal" usually has a known/expected limited-range spectrum ("uses only some selected frequencies")
- usually you will filter most of the noise frequencies to keep the signal frequencies (with low-pass or band-pass filters)…
03-19-2018 06:05 AM
Hi Herd,
Thanks a lot for the explanation. As I found the frequency component of my signal to be 50Hz using Extract signal tone Information VI. I design a lowpass pass filter at fc=50Hz inoder to reject the noise. Am I right.??
Best Regards
Deepa
