How to add header to spreadsheet?
I have a spreasheet file, 9 columns of integer x multiple rows. I would like to add a header to the top, Sample #, Max, Min, 1 sec, 2 sec....... Thank you.
(984 Views)
If you can, download and install the Report Generation Toolkit.  It has those options within it to add header information to your file.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(966 Views)
First write an array of strings for your headers. Then call the write function again with "append data" set to "true" to write your numeric values.
(950 Views)
