How to access or get RFID UID using omnikey cardman 5421.
I am new in RFID card reader application. i just want to know how to configure a connection using labview, my hardware is HID OMNIKEY 5421 and is connected to USB.
I used the code in this link http://forums.ni.com/t5/LabVIEW/Using-labview-how-do-I-access-the-smart-card-with-the-smart-card/td-... for me to start and check if i can get a return value.
im using a pc with OS: windows 7 64-bit and LabVIEW 2011.
hardware used with card inserted using omnikey workbench:
(4,562 Views)
From the image you have posted it seems it was a Mifare memory card which will just provide UID and not ATR (Both are different).
@Earl_M. wrote:
I used the code to start and check if i can get a return value.
So what you got? Any errors? Upto scardconnect function it will work and return UID. Let us know in detail what problems you face.
Mathan
(4,526 Views)
I get a return code of 80100069, i look for the meaning of it and below is the description the the return code.
SCARD_W_REMOVED_CARD
0x80100069
The smart card has been removed, so further communication is not possible.
and also the return code of scardstatus it "6" which is error_invalid_handle. Even if i placed the card on top of the reader. The same values i get if i remove the card.
Earl
(4,512 Views)
Accepted by topic author Earl_M.
i finally get the solution for my query.
here is the link i used to get the UID of my card.
https://forums.ni.com/t5/LabVIEW/pc-sc-Scardtransmit/td-p/815089/page/5
using the attached file in the link, i can now modify to the needs of my application.
thanks,
Earl
(4,498 Views)
(4,152 Views)
