How to Save a Table Data to Excel File
Hi Does anyone know how to save data on labview table , I want to save those data to excel file.
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
Message 1 of 20
(12,530 Views)
Accepted by topic author syrpimp
Duplicate Post
https://forums.ni.com/t5/LabVIEW/How-to-Save-a-multicolumn-listbox-Data-to-Excel-File/m-p/2974581
U can use,
1. Write To Spreadsheet File.vi
2. Report Generation Tool kit
Munna
Message 2 of 20
(12,513 Views)
Why would you ask this again when you marked the question as solved in your other thread?
Message 3 of 20
(12,496 Views)
Perhaps the OP is not satisfied with a ASCII text file being opened in Excel, and actually wants a XLS or XLSX file.  If that is the case checkout the Report Generation Toolkit which now comes with some versions of LabVIEW 2014, or look at XLR8.
Message 4 of 20
(12,460 Views)
You know if you make a text file with a TAB delimiter and give the file a .xls extension it opens in Excel just fine. I do it all the time.
=== Engineer Ambiguously ===
Message 5 of 20
(12,452 Views)
NO. It does not open "just fine" because it's not an Excel file.
I wish people would STOP DOING THIS. Don't ever EVER put a .xls or any other file extension used by a licensed and or commercial application on a plain text file.
This kind of practice makes LabVIEW programmers look like rank amateurs.
STOP IT. NOW.
PaulG.
LabVIEW versions 5.0 - 2020
“All programmers are optimists”
― Frederick P. Brooks Jr.
Message 6 of 20
(12,428 Views)
You really should not do that.  It makes Excel do extra work.   But Excel can open up *.txt files just fine.  So I save my tab delimited text files with an extention of txt and then edit them with Excel.
GCentral
Message 7 of 20
(12,418 Views)
We should also mention that the Write Measurement File Express VI can save data with an xlsx format.  Yes, it is the true format that Excel uses.  So if you already have all of the data, that might be a really good way to go.
GCentral
Message 8 of 20
(12,415 Views)
Yes, but you have to go through the "import"  process every time and tell Excel the file is tab delimited, that's a P.I.T.A.
And it confuses my managers if I send them a raw data file that will not open directly in Excel by double clicking on it, as double clicking a txt file opens in Notepad by default.
Putting a .xls opens it right up in Excel, but Excel 2010 and newer will say it's not really an Excel file but allow you to open it anyway.
Right or wrong I find it is eaiser for everyone if I do that.
Message 9 of 20
(12,370 Views)
STOP IT. NOW.
I have been doing this for 20 years becasuse it confuses my managers if I send them a raw data file that will not open directly in Excel by double clicking on it.
Right or wrong I find it is eaiser for everyone if I do that, and I am not going to stop now.
Message 10 of 20
(12,367 Views)
