How to Make an VI of IntServ
hi
 i need help in the to make  integration of two vi (DiffServ,IntServ) attached with this  email  as my topic is integration of differentiated services and Integrated services ..
how i can integrates these two VIs
thanks
Message 11 of 16
(1,543 Views)
The first thing to do is to wire your inputs and outputs to each VI's connector pane. In Diffserv, you have one of each. In Intserv, you only have an output. Once you've done that, you can put both in a top level VI and call them how you want.
Message 12 of 16
(1,535 Views)
i can understand
Kindly make VI  so i can understand properly
thanks for reply
Message 13 of 16
(1,513 Views)
What part don't you understand? I'm pretty sure that both are explained in all of the basic LabVIEW tutorials but I'll try to help you explain about connector panes and terminals. If you go up to the icon in the upper right corner of a VI, you can right click and select  'Show Connector'. This will display a pattern of boxes. These little boxes are connection points for the VI's terminals and controls. I you move your mouse over the connector pane, it will change to a wire tool. For your Diffser VI, click the box on the left side and then click on your 'e' control. You have now wired a control to the connector pane and it is through the connector pane that a higher level VI can pass data to your subVI. You can then move the mouse back to the connector pane and click on the little box in the upper right corner. Then click on your array called 'Delay'. You have now wired and indicator to the connector pane and and it is through this that the subVI will pass data back to a calling VI. By convention, inputs go on the left side of the connector and outputs go on the right side. There is a whole section in the on-line help under the 'connector panes>assigning terminals' topic.
Message 14 of 16
(1,506 Views)
i tried to make but it is not
kindly see my vi
Message 15 of 16
(1,487 Views)
I'm sorry but the changes you made are completely incomprehensible to me. It looks like you made some random connections. You cannot wire two data sources together as you have done and you just can't wire an array to a scalar. maybe if you explained what data is supposed to be common to the two different loops, someone can help you.
Message 16 of 16
(1,481 Views)
