07-02-2013 09:58 AM
I am currently working on a program to measure various properties of different materials. In order to do this, I have three different measurement locations. I am using the Keithley 7001 scanner to select which source to measure and a Keithley 2182 to do the measuring. Unfortunately, I am having issues having the two work together. I have tried using a sequence structure and also simply having the two run at the same time; with the sequence structure, the Scanner selects which channel to run and then closes it before the next sequence (2182) begins, which makes sense, but when both run at the same time the scanner selects a channel and then deselects at nearly the same time as the 2182 takes the measurement. I tried using a time delay to delay the 2182 measurement while the 7001 has not chosen a channel, but this also didn't work. I have been using LabView for four weeks, so I was wondering if anyone with more experience has any suggestions as to having the two work together.
I have attached the VI. To save space I compiled the various initialization drivers for the 7001 into a subVI, inside of which are some items that may help.
07-03-2013 01:48 PM
Have you downloaded the driver for Keithley 7001 and 2182 from our website ni.com/idnet?
http://zone.ni.com/devzone/cda/epd/p/id/354
07-03-2013 01:55 PM
I couldn't open your vi (i use 2009) but I have experience with the 7001. The device keeps a switch closed until YOU open it. So there is definately an issue with your vi not waiting for the measurement routine to finish. Since you are running a state machine, adding wait timers should be unnecessary. How are you communicating with the devices? GPIB?
Post a 2009 version and I'll try to take a look.
07-03-2013 05:49 PM
