01-21-2022 10:26 AM
I've got VI references open; the references are in a variety of places in the code and most of the FPs are closed.
Now I want the code to open a new VI reference, but before I do that, I want to make sure that there won't be a name conflict.
This will give me the qualified name of the VI before I try to open it:
I thought I could use this to check what's already in memory:
But a VI only shows up in that list if its FP is open. If the FP is closed, it won't be in the list even though an open ref is holding it in memory.
How can I find out what VIs really are in memory (other than keeping track myself)?
01-21-2022 12:27 PM
That node does return VIs in memory in the application without open FPs. Are you sure it is running in the same application instance (project)?
01-22-2022 08:52 AM
It turns out that whether or not it works depends on the context.
01-24-2022 03:11 AM - edited 01-24-2022 03:14 AM
@paul_cardinale wrote:I thought I could use this to check what's already in memory:
That's just not true.
If I open a project, and call this method, all class member VIs will show, and their front panels are definitely not open.
It won't show clones though, even if the front panel is open.
And yes, it shows VIs in context memory. Somewhere in LabVIEW's history application instance and context seem to got mixed... The help does mention it shows VIs in application instance, but I think that help was created before the concept of contexts.
01-24-2022 06:18 AM
Try the code that I posted. The VI ref is open, but the VI is not listed.
01-24-2022 08:09 AM - edited 01-24-2022 08:47 AM
That seems to be an update problem.
If you put a while loop around the Get All VIs In Memory it will return Dyn.vi at some point.
It seems to always update the list when I create a probe (EDIT: probe a wire, not create a new probe) in the current context.
01-24-2022 08:55 AM
Also, the VI is in All System VIs In Memory, straight from the start.
Apparently, it's a system VI until some trigger (the probe in current context), and then it becomes a normal VI.
I'd concatenate System VIs In Memory and VIs In Memory, as both are probably small arrays anyways.
01-24-2022 08:57 AM
What exactly does it mean for a VI to be a "System VI"?
01-24-2022 09:12 AM
It means the "Is System VI" property is true.
Or apparently that the VI is loaded in a new host context, and the context isn't updated yet 😎.
It has consequences for searching (system VIs are not searched, nor found, IIRC) and (IIRC) the VI Hierarchy Window (system VIs won't show up). Maybe a few other places...
