09-30-2019 01:36 AM
hi,
how to find CAN Frame Receiving Time Delay.
09-30-2019 02:35 AM
09-30-2019 03:43 AM
Receiving CAN Frame Response time.
09-30-2019 03:53 AM - edited 09-30-2019 03:53 AM
Hi Gokul,
CAN messages usually come with a timestamp.
So you know when you send them and you can read when you received the answer.
What's exactly your problem?
Mind to write more text in your message than just that?
09-30-2019 05:54 AM
hi,
I can't able to find timestamp in CAN Receive frame.please find the my code for your Reference.
Details:
Labview :2016
Diagnostic tool kit(UDS)
Send Commad: 10 03
Receive Commad:50 03 XX XX XX
i want time delay between TX and RX Frame using this tool kit.
09-30-2019 06:10 AM
Hi Gokul,
I see them in "default" CAN messages, like shown here:
Details:Diagnostic tool kit(UDS)
It's the first time you mention that diagnostic toolkit: read it's help to learn about its options. (I don't have bought/installed that toolkit.)
Use "plain" CAN functions when you want to get their functionality…
09-30-2019 06:35 AM
i can't able to use default CAN Message because my architecture is already defined in Diagnostic tool kit only.
any other way using diagnostic tool kit find the response time.
09-30-2019 10:48 AM
See http://zone.ni.com/reference/en-XX/help/372140J-01/adcs/gettimestampvi/
Assuming you are using ISO TP (which the send and receive commands you mention appear to), the get time stamp vi should help you. The Send Command is a SF, as is the receive command.
Also note that you don't need to use Diagnostic Service.vi for this. You can use UDS Diagnostic Session Control instead (http://zone.ni.com/reference/en-XX/help/372140J-01/adcs/udsdiagnosticsessioncontrolvi/). If you want to stay in extended diagnostic mode, you will probably also need to periodically send a tester present message (http://zone.ni.com/reference/en-XX/help/372140J-01/adcs/udstesterpresentvi/).
