06-07-2012 07:49 AM
@MoReese wrote:
@Ben wrote:
In control editor;
Set control as Strict
File >>> Apply changes
Set control as normal type def
save and continue as normal.
Ben
Interesting. I never considering this before. What limitations of property nodes are you referring to with the use of Strict Type defs?
I don't have them memorized but I believe the background color is one of them.
Ben
06-07-2012 07:53 AM
@CarmineS wrote:
The "THIS" is the two prior posts. First using 1D or 2D arrays AND using strict typedef.
Both together solve my question. Since the number of replies was minimal I thought the solution was obvious.
Hope that helps.
There were three suggestions. So no, the solution is not obvious.
06-07-2012 07:56 AM
Ben
I don't doubt what you say. I have just never run into this situation yet. But thanks for the tip. I'll keep it in mind.
06-07-2012 08:50 AM
Another option that not only will allow you to make cosmetic changes and syndicate them to all of your controls but also will let you encapsulate other logic is Xcontrols they are very powerful for this and much much more.
