08-05-2009 03:11 AM
I want to search in the first column of a Excel file a name and when I found it I want to read the near cells (same row but different column).
I try with the Activex but I don't found the rigth solution.
Can I help me, please?
08-05-2009 03:27 AM
08-05-2009 03:28 AM
08-05-2009 03:35 AM
Hey giada,
Before you can use the read from spreadsheet file VI the data of the Excel file must be copied to a .txt file then using the VI mentioned when set to string you can perform array searches to the data
I shall write you an example to show the search aspect of your problem
08-05-2009 03:39 AM
08-05-2009 03:45 AM
08-05-2009 03:50 AM
Sorry, but I have LabView 8.5.1.
08-05-2009 03:53 AM
08-05-2009 04:22 AM
This will Search the Excel file for you
Hope this helps
