Hi. You must create a new VI with a XY graph on it, and customize the graph
in the vay you want to appear on the paper ( less black color, ...). You
must select "Show Front Panel When Called" and "Close Afterwards When Originaly
Closed" options in VI Setup - pop-up with the mouse on the icon in the upper-right
corner. You must wire the graph to conector pane - same VI Setup - Show connector,
and use this VI in your VI, wirring the original XY graph to the input in
this printing VI. You can customize the printing format in "File->Print Documentation"
Hope it works,
Vlad
