To check this and other specs for the 7030devices I recommend checking the device's manual.
See page A-1 on the RT Series DAQ Device User Manual (there is 8 MB user-programmable DRAM for your program and data)
This is the link to the manual:
http://digital.ni.com/manuals.nsf/websearch/0F755D77A8C00450862569E700601FC1?OpenDocument&node=132100_US
Also a good document that you might check for memory managemente is "Labview RT memory management", check that the best thing to do is preallocate memory before using it. To preallocate just create a dummy array of the desired size:
http://zone.ni.com/devzone/conceptd.nsf/2d17d611efb58b22862567a9006ffe76/adde63e507afe8ad86256acb005def2f?OpenDocument
Blasioz Valenzuela
National Instrumen
ts
