Manuel,
It
sounds like your task "TRAIN_PULSE_GEN" might be trying to produce a finite pulse train using Counter 6. To do so, DAQmx wants to use the paired counter, Counter 7, to control the # of pulses to generate. However Counter 7 is also needed for your "PULSE_COUNT" task, creating a conflict.
Possible workarounds:
A. Generate a continuous pulse train on Counter 6. Probably this won't work for you app so how about...
B. Only use Counters 0..4 for SINGLE_PULSE tasks, and setup your "PULSE_COUNT" task on Counter 5. Then your finite pulse train on Counter 6 can work because Counter 7 has been left available. If your app won't allow only 5 single pulse sources rather than 6, then you'll probably need to buy an additional counter/timer board. A 6601 may be sufficient.
Now, your specific questions:
1. If it is possible to generate several single pulses within the same task. Why isn't to generate several trains of pulses in the same task?Yes you can generate up to 8 single pulses, though they will each actually be assigned a unique task. You also could generate up to 4 finite pulse trains provided no counters were reserved for other tasks. And you could generate up to 8 continuous pulse trains. None of these pulse generation tasks require DMA.
2. How many task can be run accessing the NI PCI-6602. Is it limited somehow by the number of DMA channels? Should I better use interrupts?You can run up to 8 counter tasks on a PCI-6602. Pulse generation does not need DMA nor do single unbuffered measurements. DMA is only used for the first 3 buffered measurements you setup. More buffered measurements can be done, but at a reduced speed because they will need to use interrupts.
None of your pulse generation tasks need DMA. I don't know if your pulse counting task is buffered or not, so it will use either 1 or 0 DMA channels. You shouldn't need to worry about using interrupts for anything in this app.
-Kevin P.
CAUTION! New LabVIEW adopters -- it's too late for me, but you *can* save yourself. The new subscription policy for LabVIEW puts NI's hand in your wallet for the rest of your working life. Are you sure you're *that* dedicated to LabVIEW? (Summary of my reasons in this post, part of a voluminous thread of mostly complaints starting here).
