A 10 KHz loop rate for one PID calculation should not be a problem with LabVIEW RT and the RT Series PXI-8170/850 MHz Controller.
A simple PID loop has been benchmarked on the 700 MHz controller at 33 KHz. This test was done with no other parallel operations - no communication or data logging, only the PID calculation. This was also done at time critical priority with hardware timing, with the AI and AO sharing a clock.
In addition, the DAQ VIs used were modified (to look like those now shipped with LabVIEW 6) to accept preallocated arrays so that no memory management occurred inside the loop.
For more information, I recommend visiting the LabVIEW Real-Time Resource Library in the Developer Zone.
Chad Humberstone
Application Engineering
