How do you write a VI that changes letters in a string?
I need to write a programm that changes every letter in a string with the next letter in the alphabet. ('a' changes to 'b' and so on) Can anyone help? (Labview 14.0)
Message 1 of 9
(6,112 Views)
z becomes a ?
Same for capitals ?
Numbers and other signs remain unchanged ?
Message 2 of 9
(6,105 Views)
yes, z become a, same for capitals and there are no numbers and symbols in the text file.
Message 3 of 9
(6,097 Views)
Convert the letter to ascii code, add 1 than convert back to letter
Message 4 of 9
(6,095 Views)
Hi daiana,
convert the string to an U8 array and add 1. Then convert back to string…
This becomes a different problem. Now I would use a lookup table (but still work with conversion to U8 array).
Message 5 of 9
(6,092 Views)
Check if the number is greater than "z" code then change the number to the ascii number equivalnt to a
Message 6 of 9
(6,085 Views)
Accepted by topic author iam_daiana
Use String To Byte Array to make an array of characters.  Then use a FOR loop (autoindexing) to do the conversion.  You will want a case structure to handle the z cases differently from the default and leave punctuation alone.  Autoindex the results out of the loop and then use Byte Array To String.
Message 7 of 9
(6,082 Views)
This will work with any characters in the text.
PS : Am I to generous by providing a code ?
Message 8 of 9
(6,056 Views)
Congratulations crossrulz for being faster !
Message 9 of 9
(6,045 Views)
