If you are just trying to measure relative sound levels or record sound for playback, the standard PC sound card is adequate. If you want to calibrate your measurements against a known standard and have accurate measurements over a wide range of frequencies, then you need something better. In that case, I would go with an NI DSA board and a high quality ICP microphone from The Modal Shop.
Bruce
Bruce Ammons
Ammons Engineering
