01-29-2003 08:25 PM
01-29-2003 10:14 PM
01-29-2003 10:36 PM
01-30-2003 11:40 AM
04-28-2006 09:16 AM
The links on this thread are old and dead. Any updates to this for LV 7.1 and 8? I'm looking for examples.
Lorna
05-02-2006 12:10 PM
Try this example. Though this was created for LabVIEW 6.1 it works in higher versions of LabVIEW as well.
Ankita
05-02-2006 01:42 PM
05-04-2006 12:38 PM
Hi Dave,
You are right about using WMP 10 since MS will at some point probably drop support for earlier versions of WMP. I have however been unable to find an example that uses newer object model. Hence I put together a quick example (test .vi). What I would suggest is open this example in LabvIEW 8.0 and understand its working. Now you can modify/add the properties to add more features to the VI. You would be able to get information about all the ActiveX properties/methods of WMP 10 at MSDN.
Ankita
