How do you pass data out of a loop prior to it's termination?
I would like to pass information out of an executing loop structure while it is still looping. As far as I can tell, values collect at the loop structure output terminal until it is done. I want to get around this!
(2,015 Views)
You can use local or global variables. If you process the information in another part (loop, vi, etc.), there is the possibility you may run into race conditions. To avoid that you can use vi's for synchronozation or detection of ocurrences. Check LabVIEW's examples in the help file, specially those in the Advance section.
Regards;
Enrique
www.vartortech.com
(2,015 Views)
Thanks a lot! I reviewed the help on those topics and that should do the trick.
(2,015 Views)
