Mont;
If you want to pass a string from LabVIEW to your dll, and you do NOT change size of the string, you can use a C String pointer (CStr), which is equivalent to (unsigned) char *.
If you do modify size of the string, pass string as a LabVIEW structure (LStrHandle).
The example "
Passing a Variety of Data Types from DLL to LabVIEW" is an excellent starting point. Also make sure you check the manual "
Using External Code in LabVIEW".
Regards;
Enrique
www.vartortech.com
