I understand that it is possible to acquire "real time" feedback from a Rensishaw Laser while measuring linear position, with the following modifiers applied.
*The standard output is a digitized value to a proprietary (Renishaw) data acquisition (DAQ) card.
*Renishaw lasers have a quadrature output facility on the back of the laser head. This permits capture of the �raw� interferometry signal. This raw signal is not compensated for environmental factors such as temperature, air pressure, humidity, etc.
*The standard system integrates signals from an environmental unit for air temperature, pressure, and humidity, as well as signals from up to three material probes. Acquisition and pro
cessing of these or equivalent signals would have to be considered to provide data for environmental compensation calculations (Edlen equation). This is mandatory in order to obtain accurate distance and velocity readings.
*The quadrature output can communicate with other cards. (NI DAQ?)
Specifics with regard to Labview software and required DAQ to read real time Laser output would be very much appreciated.
