I'm using the signal coming out from the 16-bit digital terminal on the front panel of the PXI-5411. I was wondering how to send a digital WORD or pattern through the outputs where the pattern is non-periodic through a short period of time?
The 16 bit output corrosponds to the buffer that is output via the arb. use the random number generator -.5*32768 to generate a random bit patttern as deep as you need. Stu
