How do you create a gauge with a non-linear non-log scale
Hello -
I'd like to create a gauge that has a scale that isn't linear or log... See that attachment for an example of such a gauge;  note that spacing between markers varies. Can this be done?  If so, how?   (My gauge in LabVIEW can have an circular shape, and need not be oriented like in the image...)
Alan
Message 1 of 9
(4,180 Views)
Maybe some ideas at this link where they wanted to remove the first and last label.
http://forums.ni.com/ni/board/message?board.id=170&message.id=308670&query.id=1023986#M308670
Message 2 of 9
(4,173 Views)
I would probably use an image as background, then do some nonlinear mapping of the value before displaying.
Message 3 of 9
(4,155 Views)
Thanks for the information and suggestions! There is a dynamic component to the project requiring multiple changing gauges, so an image isn't feasible, but would definitely be the obvious choice otherwise.  The text label approach looks good, but it's frustrating that you can put the markers in arbitrary positions in this mode.
Cheers,
Alan
Message 4 of 9
(4,146 Views)
What do you mean by "multiple changing gauges"?  How would an image for each gauge not satisfy this?
Alex Person
NI-RIO Product Support Engineer
Message 5 of 9
(4,112 Views)
The nonlinear (nonlog) relation is between x and xStar, you choosed a log-scale grid, so I assume the 'linear' scale should be adjusted.
Since the relatiion x -> xStar is given and fixed for a scale, you can create a picture on top of the graph with the picture tools.
read the log scale min and max, read the x pixel length of the plot area  and whenever the scale is changed (event) recalculate and draw the 'lin' scale.
-draw the minor ticks  , draw the major ticks and numbers.
I would simply use one scale, add a cursor, lock it to the plot and use the cusor change even (read pointindex, get x,y from data) to display x,xStar and y
Greetings from Germany
Henrik
LV since v3.1
Message 6 of 9
(3,607 Views)
here is a cursor example
Henrik
LV since v3.1
Message 7 of 9
(3,600 Views)
We are missing some subVIs.
Message 8 of 9
(3,585 Views)
Sorry, post belongs to this thread
http://forums.ni.com/t5/LabVIEW/XY-Graph-overlaying-linear-log-scale-data
Henrik
LV since v3.1
Message 9 of 9
(3,545 Views)
