How do you control the order of operations inside a LabView “VI”?
(7,848 Views)
Are you talking daq operations or daq assistants or other (math or comparison)?
___________________________________________________________________
Still confused after 8 years.
(7,844 Views)
Dataflow determines the order. A common method is to use error in/out connections. Try to avoid the flat sequence structure and never use the stacked sequence structure.
Take some of free tutorials to get a better understanding.
(7,823 Views)
The error in/out was going to be my suggestion.
(7,805 Views)
Using the flat sequence structure when a component, like timers or other  "free standing" ones that don't have error clusters to force data flow.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(7,789 Views)
You got some good advice already, but let me emphasize that  for the vast majority of operations the order does not matter and is sufficiently determined by dataflow alone. Heavy handedly adding error wires everywhere causes excessive serialization and leaves no leeway for the compiler to optimize the code for parallel execution of code that can be independent.
Order of operations is important for IO operations, and here the error wire is sufficient to enforce order. On a higher level, order is enforced by proper code architecture, such as state machines.
(A typical beginner mistake is the excessive use of local variables, which breaks data dependency and the natural order of execution, which them must be restored by excessive use of sequence structures. Two wrongs don't make a right!)
(7,780 Views)
In this case, you could use use a case structure and wire the error into that.  In the case of the error, the wait is meaningless.  You bypass the wait.  In the no error case, it operates the same as the FSS.  You gain functionality by changing from FSS to case structure.
(7,749 Views)
