Hi Aly,
you could run a "shiping" (quite hidden) VI to register the LabVIEW DSC OPC Server. Normally this should be executed by the first start of LabVIEW after the DSC installation.
This VI is located under \vi.lib\lvdsc\Srvrlibs\OPC and is called 'Register OPC Server.vi'. If you run this VI it would set the correct CLSID.
Hope this helps
Roland
PS: The only reason I can think of using this VI in regular circumstances would be, if you have serveral versions of LabVIEW DSC or LabVIEW DSC Run-Time Systems installed on the same computer. There could be just one version running and registerd as OPC server. To change the registration you could run the mentioned VI.
A second possibility to re-register and check all the Servers (VI-based, proxi
es and OPC) could be done by launching the dsc_DYN_CheckAllSrvrs.vi from vi.lib\lvdsc\_dsc.llb\
