How do you calculate the slope of a line
I am trying to calculate the slope of a line between two distinct points (4 deg/sec and 298 deg/sec).  I am using a Threshold 1D array to intiate the calculation at 4 deg/sec but I don't know how to stop the calcuation at 298 deg/sec.  I have attached the VI and an example of the text file I running through it.  Any help would be greatly appreciated.  Thanks.
(3,235 Views)
Just use anothe threshold array wired into a split array split array
"Should be" isn't "Is" -Jay
(3,227 Views)
Do another threshold at 298 and use it to calculate the lenght input for "array" subset.
(Of course you would probably need a little bit mode code to deal with pathological data....)
(3,226 Views)
Smiley Surprised
a BUG?  Christian I'm shocked!
(change the value of the dbl from 296 to 298 and round up)
(3,220 Views)
Got it!  Thank you, I have literally spent hours trying to figure this out.  I'm obviously quite a LabVIEW rookie:)
(3,211 Views)
Not a bug, just a typo. 😄
We get fractional indices anyway and there are plenty of points, so I did not worry about rounding or precision (I doubt one point would dramatically change the slope). Nothing a +1 or -1 here or there cannot fix if needed. 😄
(3,210 Views)
