How do you access a function from a winsock2.dll that has parameters with structures
Hi! I need to access winsock2 functions. The function that I need is bind, the prototype is:
int bind(SOCKET s, const struct sockaddr *name, int namelen);
The structure is
struct sockaddr {
u_short sa_family;
char sa_data[14];
And what I need to "translate" from C to Labview is
main ()
{ SOCKET s;
//some instructions
struct sockaddr name;
name.sa_family=AF_J1850;
strcpy(name.sa_data,"COM2");
bind (s, &name, 7);
//some extra code
I've been reading, and I think I must create a cluster, and the cluster will be the structure, but I'm not sure. So If someone can help me,I'd appreciated it!
Catalina
(2,813 Views)
Check out this post .
(2,813 Views)
It is impossible to built a cluster that is similar to a struct. You can
have a lock
at the funny bullshut code that represets a cluster in when you wire a
cluster
into a CIN (Code interface node). you can input a byte array and format it
like
the struckt which is in fact the same - first struct element (bytesize)
first array element
"Catalina" wrote in message
news:50650000000800000020720000-1042324653000@exchange.ni.com...
> The structure is
> struct sockaddr {
> u_short sa_family;
> char sa_data[14];
C to Labview is
> main ()
> { SOCKET s;
> //some instructions
> bind (s, &name, 7);
> //some extra code
> help me,I'd appreciated it! Thanks
> Catalina
(2,813 Views)
