09-06-2001 12:31 PM
09-07-2001 11:24 AM
06-04-2002 01:59 PM
01-30-2007 05:16 PM
01-31-2007 03:14 PM
Hi Dushyant,
You can use the Automation Open VI (From the Functions Palette go to Connectivity » Active X » Select Active X
Class) in LabVIEW. Then, right click on that VI and Select Active
X Class. From here you will need to select the Active X Class of your
USB camera. Now you can connect Property Nodes and Invoke Nodes to access
the properties and methods of this class. Please let me know
Please take a look at this, and let me know if you have any questions.
Best of luck on your application and have a wonderful day!!
01-31-2007 04:46 PM
02-02-2007
08:17 AM
- last edited on
03-26-2025
10:47 AM
by
Content Cleaner
Hi Mozill,
You will need to contact the camera manufacturer for the name of the ActiveX class. Though LabVIEW provides an ActiveX interface, it does not identify which class relates to a specific product.
If your camera meets the requirements and you have the NI Vision Development Module, you will be able to use our NI-IMAQ for USB Driver.
Please let me know if you have any further questions. Best of luck on your application, and have a great weekend!!!
02-06-2007
04:12 PM
- last edited on
03-13-2025
01:06 PM
by
Content Cleaner
Dear Ching,
I did get hold of the activex drivers for my usb web camera. I discovered if from the ksproxy.ax, kstvtune.ax, kswdmcap.ax, ksxbar.ax, NUVision.ax, and vidcap.ax. However, when I try to browse the same drivers through the 'select ActiveX Class' shortcut menu on 'automation open' box, I cant find them. So, I tried browsing them through the window/system32/ folder. I do see the .dll files, .ax files, etc, but I am not sure if I can use them.
Other question I have is about your last comment on use of "NI Vision Development Module" and "NI-IMAQ for USB Driver".
I would like to know if I can just donwload the addon as free; because I have heard about the vision software for which I have to pay very high price. I am totally new to the vision area of the LABVIEW. I would really appreciate if you give me a step by step procedure.
Thank you for your time.
02-07-2007 05:24 PM
Hi Mozill,
If you would like to call the dll files that came with your camera, you can use
the Call Library Function Node. To get more information on this, please
look at the LabVIEW Help under Call Library Function Node. The functions
that you call using this Call Library Function Node should be documented by the
camera manufacturer.
As for the .ax files, these seem to be the files from the DirectShow Filter. There is no way to access these files
directly in LabVIEW. You may be able to
access them through the dll’s that you have been given.
Though the NI-IMAQ for USB Driver is a free download, it will not work without
the NI Vision Development Module (which must be purchased).
Please let me know if you have any further questions. Best of luck on your application, and have a great day!!
