How do I use the DAQ Assistant subVI to display voltage readings from a potentiometer
And why don't you have the AI gnd connected to anything?
Message 21 of 28
(702 Views)
is that the ground on the DAQ terminal? should it be connected to an external ground?
Message 22 of 28
(699 Views)
Read about wiring.
Message 23 of 28
(693 Views)
ok so from my understanding if i am using the RSE configuration I need to wire one reference of the pot to the + terminal of my power supply, the other reference to the - terminal of the power supply and the wiper to the CH +0 pin on the DAQ. Then I also need to wire the - terminal of the power supply to the AI ground pin on the DAQ.
Message 24 of 28
(686 Views)
I tried the following RSE terminal configuration, however I am still getting the same results as before.
Message 25 of 28
(671 Views)
Have you tried measuring the voltage difference between the wiper and ground using a DMM?  The best thing to do is to verify that the signal is correct before we begin reading it using a DAQ device.
Message 27 of 28
(651 Views)
Yeah when i measure the voltage with a DMM I get the correct results. The Dmm reads 5v when the actuator is not extended, then it moves to 0 volts as I extend the actutor.
Message 28 of 28
(631 Views)
