03-16-2006 02:14 PM
03-17-2006 04:36 PM
John23,
In your task, if you right click on the channel, you should have the option to "Change to Global". Try this and let me know if it carries the calibration data over.
LA
03-17-2006 05:29 PM
03-20-2006 11:22 AM
Hi John,
It is always good to have the latest versions of the DAQ drivers. I think that you are right clicking on the task itself when you get the "rename" and "delete" options. If you right click on the channel within the task, then you should see the "change to global" option.
Hal L.
