Hi Dennis,
Do you know if it works in LV5.1?
Sergio.
Dennis Knutson wrote:
> One way is an API call. NI has an example of that. If you do a search
> for "hourglass" in their example program database, you should find it.
> Another way is in the attached file. This method I got from the
> LabVIEW version of the TestStand run-time user interface. It's in
> LabVIEW 6.
> hourglass_display.llb Type: unspecified type (application/octet-stream)
> Encoding: base64
> Description: Hourglass Display
Sergio Ricardo Pereira Perillo
MSc. em Engenharia Nuclear
Instituto de Pesquisas Energéticas e Nucleares IPEN-CNEN/SP
Área de Monitoração e Diagnóstico
Travessa R, 400 Cidade Universitária
São Paulo-SP
CEP:05508-900
Brasil
Fax: +5511 3816-9432
Telefone: +5511 3816-9164
