Most digital i/o boards are driven by various peeks/pokes to their registers
(the manufacturers literature should/will detail these).
Search the NI developer zone - some kind person may have already written a
driver for it.
If you need to write your own driver use the out port and in port vi's
included under the advanced/memory menu. Note however that these will not
work with NT based operating systems (win 2000,nt,xp etc..)- you'll need to
find a library of vi's called 'accesshw' from the developer zone and use
these instead. They basically use a dll to call the low level registers.
Hope this helps
Andy
"RJF" wrote in message
news:506500000008000000FF370000-1007855737000@exchange.ni.com...
> The board is installed in the computer.
> With Basi
c it is just an out command "out 770,128" to configure and
> control the card. The board is a Cyberresearch CYDIO24H. Thank-you Bob
