We are running a LabVIEW 6.1 executable on a PC with Windows2000. We have remote panels enabled and the system seems to be working fine. However, we would like to be able to run the Remote Panel Connection Manager in order to monitor the load we placing on our communications system. I can run it while in development mode, but the option is no longer available under Tools once I create the exe. On the actual server machines we do not have the full development system (only the runtime engine) installed. Is there a way to run the Remote Panel Connection Manager while running just the exe with the runtime engine?
