How do I rotate a laser head 22.5 degrees CW using code?
We built a laser profiler to compare with a commercial unit. The laser works great and we get great data but our laser pies are rotated 22.5 degrees CCW; in a circle there are 1024 data points or 2.8444 data points per degree so I thought of taking 64 data points(22.5 degrees) from the bottom of the array and moving them to the top of the array but its not doing what I thought, any ideas? I attached the VI with the change that was made(the for loop after the raw in and processed in) thanks in advance.
(2,644 Views)
Rotate array
(2,627 Views)
