How do I rename channel in VI
Could someone explain to me in a basic way .How to rename the merged channel names in the attched VI.
By default they read Untitled , Untitled_1 , and so on. I want to give them logic names like Coil Temp, Battery Temp etc...
---------------"Learning Never Ends" -------------------- Rakum42---------------
(3,446 Views)
 Can you post the image of your Vi's block diagram. For some reason I am not able to open it. What version of LV are you using?
CLD
(3,417 Views)
You need to set the waveform attribute as shown here. You could also use the Write to Spreadsheet function and write the headers before writing the data.
(3,404 Views)
Ivrat
I have attached the JPEG of the VI
(3,383 Views)
Accepted by topic author wipertale
Why post another image when you have already posted one, a VI, gotten an answer.
If you insist on using Write to Measurement File and insist on having channel names, you must use the procedure I linked to. At least give it a try before posting back.
(3,371 Views)
Dennis
" IDL (programming language)" ????
This is the link you suggested I look at. I hope its the right link, cos it aint making any sence and it anit straight forward.
http://en.wikipedia.org/wiki/IDL_%28programming_language%29
(3,352 Views)
