How do I read data from CR1000 datalogger?
I'm trying to connect and read data from a CR1000 datalogger that I have set up as a modbus slave by using the following code in CRBasic:
ModBusSlave(Com Port, BaudRate, ModBusAddress, ModBusVariable, BooleanVariable)
ModBusSlave(ComRS232,115200,1,PPMes(),0)
 My problem is I can't figure out how to connect to the logger and read the data in Labview. The CR1000 is connected to my computer on COM4, using a RS232 to USB converter, which I hear don't always work, although I have seemingly connected to the data logger through the application control wizard. The logger uses a RTU modbus frame but when it asks what line do I want to write to the logger I have no idea what to send to retrieve and parse the data. I've also been reading that I could use the write and read VISA controls but I'm not sure how to do that even after looking at the example. I have downloaded the NI-VISA and NI-Modbus packages. I have also seemingly been able to connect to the logger using the modbus slave/master example but again I don't know what to do to retrieve the data. I'm sorry to be asking such basic questions but while I have a reasonable handle on CRBasic programming and the general Labview functions and controls I really have no idea what I'm doing here so any help would be appreciated.
(3,964 Views)
Hi iaingidley,
From the LabVIEW side of things, what are you using to try and make this connection?  If you could post a screenshot or the name of the example you're working with, I'd appreciate it, and then can work from there to make sure connection is established.
Dave C
(3,935 Views)
